Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Newbie requires help!!! Picotrain Room Acoustics, Audio and Video Calibration 0 14-01-2008 10:03 PM
Newbie requires desperate help please ? Norbreck21a Interconnects, Speaker Cables and Switches 2 03-12-2007 4:40 PM
Newbie requires help on AV pre-out to second amp? Simon G5 AV Amplifiers and Receivers 9 15-11-2006 3:35 PM
Newbie Requires Help Soapysoap AV Amplifiers and Receivers 1 18-09-2005 4:37 PM
newbie requires help..... adi Music 1 24-01-2003 3:35 PM
Old 31-03-2008, 10:09 PM   #1 (permalink)
Thanks: Gave 1, Got 0
I've recently purchased a second hand Panasonic TX32PD30 which apparently is a very good CRT TV.
Now, I'm really a novice when it comes to getting the best out of home cinema equipment. What do I need to get the best possible picture?
I have a freeview box and DVD player. I'm quite happy with the sound so Im not looking to get that wired up to speakers or anything but I just want to know what's the best set up for the picture? I'm not really clued up on scarts or rpg or HDMI so I'm just looking for advice.
Any help will be appreciated!
nedludd is offline   Reply With Quote
Old 01-04-2008, 10:16 AM   #2 (permalink)
Thanks: Gave 24, Got 39
Re: Newbie requires help
Yes, you have one of the best CRT models ever produced (although some would argue!).
Make sure you are using RGB feeds for the Freeview and DVD boxes.
Good quality scart leads are a must, although you don't need to spend a fortune.
Perhaps invest in a calibration DVD for best picture set-up.
There's lots of info on the Forum if you do a search.
Good luck.
Tight Git is offline   Reply With Quote
Old 01-04-2008, 10:25 AM   #3 (permalink)
Thanks for that reply - very helpful. I did do a search on the forum but have to admit that I was slightly confused. I think it's just a case of getting used to the jargon.
Old 01-04-2008, 11:17 PM   #4 (permalink)
Thanks: Gave 6, Got 6
Avoid rpg at all costs, it will destroy the TV and most of your house to-boot.
rpg - Rocket Propelled Grenade!!!
Gammy leg is offline   Reply With Quote
newbie, requires
