Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
DMTECH "new" TV/DVD Combi models info WalterWood LCD Televisions 2 03-01-2008 11:41 AM
Batman tv/dvd combi Woolworths Soprano Blu-ray and DVD Player Multiregion Hacks 3 09-08-2006 1:09 AM
Batman, Batman Returns, Batman Forever & the pile of Pooh that is B&R - in DTS!! Family Guy Movies and The Cinema 23 30-11-2005 10:25 AM
Sharp DV-RW250H DVD Combi hack " Orion " HelloTech Blu-ray and DVD Player Multiregion Hacks 0 24-08-2005 7:53 AM
Adam West "Batman" TV series on DVD the_pauley Movies and The Cinema 11 20-02-2004 1:04 AM
Old 21-03-2008, 5:21 PM   #1 (permalink)
Batman 14" TV DVD Combi
Anyone know anything about these sets from Woolworths. It designed to look like Batmans head!! I'm trying to repair one and can't find any tech info. Fault is unlocked colour, changed the STV2247H and both crystals. Suspecting an EEPROM fault. Does anyone know chassis type, or service codes, or even seen thois fault before? No response from Wollies customer service.
Andy
adyson is offline   Reply With Quote
Old 21-03-2008, 7:54 PM   #2 (permalink)
Thanks: Gave 4, Got 36
Smile Re: Batman 14" TV DVD Combi
Any idea what chassis is fitted? What is the ic line up etc.
mechanic is offline   Reply With Quote
Old 21-03-2008, 8:27 PM   #3 (permalink)
It's not the usual Vestel types that you see. There are no markings whatsoever. The TV is imported from a firm called Kidscape International in Tiawan by Woolies. Their website is of no use.
The main chip is the STV2247H. This does pretty much everything from IF in to RGB out to the cathode amps, including line & frame drive, sound, OSD etc. I've got the datasheet for it, and the circuitry around the chip is pretty much copied from the data sheetThere is an unknown micro and associated EEPROM. Fault is same with SCART input so must be post IF stage. STV2247 runs very warm, and the pictures gets darker over about 15 minutes, freezing the chip restores the brightness, (but not the colour). All supply lines are at normal levels.
I've tried swapping the STV and both the crystals, interestingly swopping the crystals kills the colour completely, although they look like normal 4.43 and 3.58 crystals to me.
Andy
Old 21-03-2008, 8:49 PM   #4 (permalink)
I would tend to agree that your problem is likely to be down to the eeprom.There is the other problem that i tend to overlook at times -think simple- is there a menu that selects the system !!
Old 22-03-2008, 9:41 AM   #5 (permalink)
Tried the NTSC/PAL settings. Its the same fault if you feed it an NTSC signal. Only time its OK is if you feed it RGB.
Andy
Old 25-03-2008, 1:10 PM   #6 (permalink)
Sorted now. Dodgy 8V reg chip.
Andy
batman 14, combi, dvd
