Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Toshiba 32ZT29B Help Needed Shersm CRT Televisions 2 10-08-2007 8:13 PM
Toshiba TV - 32ZT29B - No Services suffolktoon CRT Televisions 1 01-01-2007 1:22 AM
Sky+ Nightmare: Jumping, signal loss, sound loss etc. MarcP Sky and Sky+ 1 17-10-2006 10:03 AM
Toshiba 32ZT29B buzzing Stompa CRT Televisions 0 09-10-2004 5:09 PM
Toshiba 32ZT29B jasonlgriffin CRT Televisions 7 02-08-2002 3:20 PM
Old 15-03-2008, 9:52 PM   #1 (permalink)
Thanks: Gave 48, Got 20
toshiba 32zt29b sound loss
well as the title says,moved the tv to clean behind it and when i put it back the bloody sound had gone off and the red stand by light which turns green when tv is on is staying red .has anyone else had this problem.i've had this tv since new and its been a belter so am very reluctant to bin it.any help would be greatly appreciated .cheers,mick.
mickylall is offline   Reply With Quote
Old 15-03-2008, 11:45 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
Re: toshiba 32zt29b sound loss
Your title is a wee bit misleading...if the set is stuck in standby with a red led...you won't have any sound or picture.
A faulty teletext module is a common cause of a stuck in standby fault.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 16-03-2008, 12:32 AM   #3 (permalink)
sorry,very bad description of the fault.the picture is on but no sound,the standby light stays red instead of turning green which i presume is telling me theres a fault.cant find manual yet and been searching internet for 2 hours before posting on here so again thanks for any help,mick
Old 16-03-2008, 1:05 AM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
If you moved the set check around the back of the set...some Toshiba models have a switch to select internal or external speakers...you've maybe brushed against it and set it to external.
JayCee
mickylall (16-03-2008), Skyvan (15-06-2009)
Old 16-03-2008, 2:01 AM   #5 (permalink)
youre absolutely spot on jaycee,i have now flicked the switch and the sound is back on.the light must have allways been red,just never noticed it.cheers very much,mick
Old 16-03-2008, 12:07 PM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
Glad to hear it.
It was the fact that you stated that you'd moved the set that gave it away.
JayCee
Skyvan (15-06-2009)
32zt29b, loss, sound, toshiba
