Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 13-03-2003, 1:45 AM   #1 (permalink)
ScorchedSoul
Posts: n/a
HELP!!! Severe interference on Panny pl4!
I am getting some real bad interence on the picture on my 32pl4. It's like picture noise, like there is bad reception.
The thing is, I only get on my sky digibox. Terrestial tv doesn't seem to have this.
I have also noticed that it seems to be worse on rgb, and less pronounced on standard scart. However the general picture quality is much better on rgb.
I am using a good scart cable with ofc cables, double shielding and gold contacts. I switched it with a freebie cable, and the probelm was the same, possibly a bit worse i'm not sure.
I just returned a ph40, and the picture quality is so much better on the pl4 except for the interference.
Can anyone help?, I would REALLY appreciate it.
BTW, could it be interence from the other cables? I have another freebie scart and two rf cables in my setup.
I really hope some one can help
Old 13-03-2003, 3:19 AM   #2 (permalink)
ScorchedSoul
Posts: n/a
ok, now i'm worried.
I disconnected everything, and left only the tv and didgibox, with one ofc, shielded gold contact scart connecting them both. No rf cables or anything.
I still get the !"£$ing noise/interference!!!
Do you think a higher quality scart cable will help, or could a s-video connection perhaps provide a better picture?
If i get a s-video connection, exactly what type of cables do i need? Someone told me i can use a normal scart cable for s-video. Is this true or do i need one of those cables with four pins?
Please can someone help???
Old 14-03-2003, 12:37 AM   #3 (permalink)
ScorchedSoul
Posts: n/a
come on guys! Some one must be able to help?
I sometimes hear the sound from another channel coming through the speakers very faintly, while i am watching another channel. It is very faint, and i can only hear when there is a queit moment on the program i am watching. Could this have anything to do with it?
Could it be a probelm with my sky box? I don't get this probelm with terrestial tv or my dvd player.
Old 14-03-2003, 1:32 AM   #4 (permalink)
p306
Posts: n/a
The reason is that somehow the analogue channel you have selected before leaks in. Set your analogue reception to VCR channel (= 0) or what ever channel that gives you black or blank screen and see what happens when you turn on your digital or DVD again.
I had the same problem with PL1 and always set my analog channel to 0 that gives black screen before switching to digibox or DVD. Then I have no interference at all. Have to live with it.
Old 14-03-2003, 11:50 PM   #5 (permalink)
ScorchedSoul
Posts: n/a
Thanks for replying!
I tried that, it didn't make a difference.
I only get this problem with sky, so i am starting to think that it is my digibox or the satellite cable. Has anyone had a similar problem, or know where i could find out?
Old 15-03-2003, 1:18 AM   #6 (permalink)
p306
Posts: n/a
But did you have the problem with your previous tv?
I mean to say you had the same peripherals as now but no such problem?
Old 17-03-2003, 8:03 PM   #7 (permalink)
ScorchedSoul
Posts: n/a
well on my original tv i didn't notice it, but i think that was becuase the picture was very blurry, and so i couldn't really see it.
Then i bought a ph40 where i started to notice it.
Now on my pl4 it is very bad, and i think this tv just shows a probelm that might have been there for a while. I say this becuase this tv is much sharper and clearer so probablu shows this faint interference.
interference, panny, pl4, severe
