Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 11-03-2003, 9:23 PM   #1 (permalink)
Thanks: Gave 1, Got 0
rgb colours washed out prob.
hi
i have an old toshiba 2857db pro logic with a toshiba s220e player. which works great in s-video via the scart lead but when i turn the dvd player to rgb although the picture is more stable the colour is washed out! altering colour on tv does not improve things. i have tried 2 scart leads although i have to say they are cheap ones that come with videos etc. Are rgb scarts different to normal scart? or should this work? (it is connected to rgb scart socket in tv)
thanks mick
Hunterm8 is offline   Reply With Quote
Old 12-03-2003, 2:43 PM   #2 (permalink)
Thanks: Gave 14, Got 4
I have that telly as well.
My RGB is very dark (contrast wise) with a greenish tint if you increase the brightness. You cannot adjust the colour (i.e. you cannot get it black&white).
Same devices (DVD player, Phillips onDigital) connected to other RGB telly are searing bright (contrast).
The only thing that might work is a device like a skydigibox with controllable contrast.
It seems many older toshibas have poor rgb. I stick with s-video.
I am planning to upgrade to ZT29, but lack of PAL progscan is making me wait.
topmba is offline   Reply With Quote
Old 12-03-2003, 7:35 PM   #3 (permalink)
Thanks for your reply. i will stick with s-video
Old 13-03-2003, 6:48 PM   #4 (permalink)
vegnomeat
Posts: n/a
on that model tv, depending which scart socket you use I think you can select either svhs or rgb input, get the wrong one and you watch in black and white
Wayne
Old 13-03-2003, 7:16 PM   #5 (permalink)
that´s right vegnomeat.
On mine you cannot use the colour control on rgb to make the picture black & white.
colours, prob, rgb, washed
