Sony 32LS60 Geometry question
When running the THX optimizer I noticed that the shape test (i.e. the 2 boxes with a circle in) isnt correct in either 4:3 or Wide
Instead of the above I am missing one edge of the outer box (left side). I can move it using the RGB picture correction but if I centre the box I am missing the lines on both left and right, this is in both 4:3 and Wide!
Is there a setting in the Service menu which can fix this?
If so, how do I get into the service menu and what should the setting be?
Cheers in advance
BBJ EDIT: I've sussed how to access the service menu but can I run the THX optimizer in the background??
__________________ Philips 32PF9641D 32" HD Ready LCD TV, Yamaha HTR-5640RDS Reciever,Sony DVP-NS76H DVD,Paradigm Monitor 5 Fronts, Paradigm CC350 Centre (Front & Rear), Wharfdale WH-2 Bi-Polar Rears, Paradigm PDR-10 Sub. Mail Me
