First off hi all
I was going to get a sony kp44ps2 projection TV but after looking through this board i noticed that there is far to much configuring of the set and there are a few problems with it so i decided against it. Thanks people you actually did me a favour here because i didnt really have room for a screen that size.
I then after much reading decided that the Toshiba 36ZD26 was the TV for me until i read the boards again. Ive seen so many post with problems with this set that its actually scared me off buying the set completely
i cant understand how you guys can be so patient with what seems to be a faulty TV model.
Anyway heres my problem. After having my first two plans for a TV smashed im left confused and i need some advice.
Please can someone recommend a TV that has an Excellent picture for watching mainly DVD movies and playing xbox. I have a budget upto around £1500. Ideally i would like a 36inch but if there is a stunning 32inch screen i would settle for that. I would like a model with 100hrz and if poss 2 rgb sockets. Im not fussed about having a digital decoder builit into the set and i have no care for the sound quality either as i have a good home cinema sound setup
CRT is preference.
Thanks to anyone that can help. Sorry if this is a boring post, but im new to televisions and am now confused and just a sheep among the wolves.
