Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 17-02-2003, 11:29 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Picture fault - Sony
Yesterday, my 2 year old Sony developed some kind of fault, whereby the colour in the bottom right hand side wasn't right. i.e colours weren't showing the same colour as they were on the other areas of the screen.
The problem had disappeared by this morning.
I'm out of warranty.
Can anyone give me an idea what the problem is, how serious it is, and what a repair is likely to cost?
Thanks.
Pete is offline   Reply With Quote
Old 17-02-2003, 11:35 PM   #2 (permalink)
Sounds like colour staining from a magnetic field etc, are there any external speakers close to the set?
AndyZetec is offline   Reply With Quote
Old 17-02-2003, 11:43 PM   #3 (permalink)
Yes, there are, but they are supposedly shielded! I'll move them further away, in any event.
If this was the cause, will the damage be permanent, or will moving the speakers away, prevent it happening again?
Old 17-02-2003, 11:48 PM   #4 (permalink)
Manuman
Posts: n/a
Move the speakers away from the TV and turn your TV off, by the power button, leave it off for 30 mins or so and switch back on, hopefully the staining will have disappeared.
Old 18-02-2003, 2:18 AM   #5 (permalink)
I had this with a 29" Sony. It was something to do with switching off/on too quickly. It was gone in the morning and only happened once more in about 6 years. I seem to remember my local Sony centre saying the degauss circuit had not come in or some such.
Sorry for rambling a bit, what I'm really trying to say is it should be OK.
Jim
auldendunn is offline   Reply With Quote
Old 18-02-2003, 2:32 AM   #6 (permalink)
Thanks: Gave 0, Got 3
Had exactly the same problem on an old 21" trinitron about 15 years ago and it was atributed to switching the set on/off too quickly..........It should sort itself out
ryanos is offline   Reply With Quote
Old 18-02-2003, 8:05 PM   #7 (permalink)
Tony_Cook
Posts: n/a
I once left a speaker too close to Sony TV when moving furniture and totally s*it myself - staining was really really bad (and telly was 1 day old). Left telly off overnight and perfect the next day.
Otherwise no probs in 10 years.
Where is my FS76 I ordered ???
Old 20-02-2003, 6:24 AM   #8 (permalink)
Tommo24
Posts: n/a
Surround speakers?
Does this problem apply to surround speakers?
I have the cube speakers supplied with the DAV770 right next to my tv with the centre speaker on top of the tv.
Is this ok?...its what it advises in the manual.
Tom
Old 20-02-2003, 9:17 PM   #9 (permalink)
Dog Man
Posts: n/a
Usually speakers won't cause a problem, if you put a speaker which has a lot of stray magnetic flux you should see it right away.
Keep an eye on applifiers though, due to the big transformers inside they tend to cause some landing errors (colour patches).
Regarding the initial problem it was probably caused by the weather. An electrical storm can cause a magnetic build-up on you CRT. Usually this will be solved during power-on (Degaussing), if it persists then you will have to use an external degauss tool.
Old 21-02-2003, 3:37 AM   #10 (permalink)
Thanks for all the replies, the problem has not returned, and the first few replies, helped put my mind at rest, 'cause I was a worried man!
fault, picture, sony
