08-12-2007, 12:27 AM
#1 (permalink)
| | New Member
Thanks: Gave 2, Got 0 | My TV's AV channel has stopped picking up my PS3
First of all apologies, I'm new to this forum and wasn't entirely sure where I should post this so I posted it here and perhaps it can be moved. Anyway:
We have had workmen putting up new guttering on our house and I think they may have knocked the aerial as I can't get any picture from sky.
But the main question I have is, would this affect the AV channel? I can't play on my PS3 as the AV channel is just a dark screen, I've tried re-tuning and everything, but I'm not the most clued up person when it comes to this sort of stuff.
It was fine last night but not now.
Cheers for any advice and once again apologies as I know this is not the correct forum.
08-12-2007, 12:45 AM
#2 (permalink)
| | Senior Member
Thanks: Gave 153, Got 56 | Re: My TV's AV channel has stopped picking up my PS3
Do you mean the dish, as the aerial wouldnt effect the sky box. The dish or aerial also wouldnt effect the av channels.
Do both sky and the ps3 both use the av channel?
it would probably be worth checking all you cable connections first.
Is it on the correct av channel?, do you have av1 av2 etc?
It doesn't matter how you find the pot of gold, all that matters is that you beat the leprechauns my_flickr |
08-12-2007, 12:50 AM
#3 (permalink)
| | New Member
Thanks: Gave 2, Got 0 | Re: My TV's AV channel has stopped picking up my PS3 Quote:
Originally Posted by coombes123 Do you mean the dish, as the aerial wouldnt effect the sky box. The dish or aerial also wouldnt effect the av channels.
Is it on the correct av channel?, do you have av1 av2 etc? | Sorry yep I meant the dish
I have never had a problem before. I think Sky perhaps does use the AV channel, I take the sky cable out when I plug the PS3 one in. I've made sure all the cables are fitted properly. It's a simple old Alba tv probably about 6 years old which just has the one AV channel.
Thanks again for your help.
08-12-2007, 1:20 AM
#4 (permalink)
| | Distinguished Member
Thanks: Gave 2,925, Got 1,853 | Re: My TV's AV channel has stopped picking up my PS3
What type of conenction are you using with your ps3, hdmi, component, composite?
08-12-2007, 1:29 AM
#5 (permalink)
| | New Member
Originally Posted by New Era What type of conenction are you using with your ps3, hdmi, component, composite? | Sorry, I really am poor with the names.
It is the basic wire that comes with it. red, white, and yellow wire connected to one of these (bloody hell I'm rubbish at explaining). |
08-12-2007, 1:40 AM
#6 (permalink)
Thanks: Gave 2,925, Got 1,853 | Re: My TV's AV channel has stopped picking up my PS3 Quote:
Originally Posted by pds1985 Sorry, I really am poor with the names.
It is the basic wire that comes with it. red, white, and yellow wire connected to one of these (bloody hell I'm rubbish at explaining). Attachment 67640 | No problem, so you're plugged into the scart socket which would indeed be the av channel on your tv. Try turning your ps3 off, then switch it on again but keep your finger on the power button until you hear a bleep. Make sure your tv is on and on the av source.
08-12-2007, 1:45 AM
#7 (permalink)
| | New Member
Originally Posted by New Era No problem, so you're plugged into the scart socket which would indeed be the av channel on your tv. Try turning your ps3 off, then switch it on again but keep your finger on the power button until you hear a bleep. Make sure your tv is on and on the av source. | Tried this, nothing but a dark blank screen with the AV sign in the top left corner.
I just don't understand it, it was fine last night.
08-12-2007, 1:47 AM
#8 (permalink)
Originally Posted by pds1985 Tried this, nothing but a dark blank screen with the AV sign in the top left corner.
I just don't understand it, it was fine last night. | I take it you've checked all the connections? Everything is connected properly? It may be worth checking incase a connection has become loose.
08-12-2007, 1:52 AM
#9 (permalink)
| | New Member
Originally Posted by New Era I take it you've checked all the connections? Everything is connected properly? It may be worth checking incase a connection has become loose. | Yeah they're all fine.
Cheers once again.
08-12-2007, 1:52 AM
#10 (permalink)
| | Senior Member
Thanks: Gave 68, Got 178 | Re: My TV's AV channel has stopped picking up my PS3
It seems to me that if you can't get a picture from either Sky or your PS3, the common factor is the TV. Scart plugs and sockets aren't really designed to be pulled in and out constantly, so you may have broken something.
I'm confused by your picture. Is that the actual adapter you are using, or just one a bit like it? The reason I ask is that you talk about red, white and yellow connectors, which would normally be right and left audio and composite video (which is a pretty bad thing to use, especially for a PS3!), but the adapter looks like it takes RGB.
08-12-2007, 1:55 AM
#11 (permalink)
Originally Posted by njp
I'm confused by your picture. Is that the actual adapter you are using, or just one a bit like it? The reason I ask is that you talk about red, white and yellow connectors, which would normally be right and left audio and composite video (which is a pretty bad thing to use, especially for a PS3!), but the adapter looks like it takes RGB. | That will just be an image of the net. He is using the bundled composite cable and scart adaptor that comes included with the ps3.
08-12-2007, 1:57 AM
#12 (permalink)
Originally Posted by njp It seems to me that if you can't get a picture from either Sky or your PS3, the common factor is the TV. Scart plugs and sockets aren't really designed to be pulled in and out constantly, so you may have broken something.
| I have to agree, if you can't get a picture from any source it's likely to be the t.v. Have you tried a dvd player etc?
08-12-2007, 1:58 AM
#13 (permalink)
| | New Member
I'm confused by your picture. Is that the actual adapter you are using, or just one a bit like it? The reason I ask is that you talk about red, white and yellow connectors, which would normally be right and left audio and composite video (which is a pretty bad thing to use, especially for a PS3!), but the adapter looks like it takes RGB. | Yep it is the red,white yellow one just couldn't find a pic of the exact one. I used it as it comes in the box, what would you recommend instead?
I have tried the PS downstairs on another t.v. and all is fine.
With Sky the picture is rolling up and down the screen. You can make out the blue colour of the menu but not much else.
08-12-2007, 2:02 AM
#14 (permalink)
Originally Posted by pds1985 Yep it is the red,white yellow one just couldn't find a pic of the exact one. I used it as it comes in the box, what would you recommend instead?
| If you have a hd tv you should be using a hdmi cable. If you are using a crt then it might be worth buying an rgb scart cable. The ps2 ones work on the ps3 |
08-12-2007, 2:07 AM
#15 (permalink)
| | New Member
Originally Posted by New Era If you have a hd tv you should be using a hdmi cable. If you are using a crt then it might be worth buying an rgb scart cable. The ps2 ones work on the ps3  | Definately not HD it's barely AD.
Looking to buy a HD tv soon but thats another question |
