Originally Posted by satfly or find a workaround by defaulting the TV to EXT 1. |
You could try this from the faqs on your model taken from
here
Question
Set channels as favourite.
Answer
Hold down both installation buttons on the remote control simultaneously.
Select FAVOURITE PROGRAMMES and press 'OK'.
Select a channel using the up or down cursor.
Change favourite mode (Yes = favourite=do not skip; No = not favourite=skip) using the left or right cursor.
Non favourite channels can be selected with numeric buttons.
So you could try skipping all prog nos you don't want leaving EXT1 unskipped as a "Favourite"
