Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Thomson box problem ? Worthywow Sky and Sky+ 3 01-07-2007 10:50 AM
Help- Thomson 160 Problem mastanlem Sky and Sky+ 2 13-02-2007 8:06 PM
HELP - Thomson 160 problem mastanlem Sky and Sky+ 0 13-02-2007 7:06 AM
Problem with Sky+ box (Thomson) soulboy Sky and Sky+ 1 17-11-2006 8:35 AM
SKY+ Thomson Problem Cowden_harley Sky and Sky+ 3 14-06-2006 6:58 AM
Old 03-12-2007, 11:33 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Problem with my old Thomson
Hi Guys,
I have a 7yr old Thomson 32KV24U crt and over the last week or so it has decised to start switching its self of whilst I am watching it and now it will not come back on (it flash when you press the power button then goes dead).
I have tried disconnecting everything from it but no joy.
Any ideas or do I need to treat it as a cloud with a silver lining and get a new LCD replacement?
Regards
Alex
alex100a is offline   Reply With Quote
Old 03-12-2007, 11:44 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
Re: Problem with my old Thomson
I suspect your model is actually a 32VK24U.
The high voltage "Line Output Transfomer" is the most common failure on this Thomson ICC17 chassis and repair costs are likely to be around £70-£100.
To be sure you'd need to call in an experienced engineer for an accurate on-site diagnosis.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
alex100a (03-12-2007)
Old 03-12-2007, 11:51 PM   #3 (permalink)
Cheers and your right it is a VK not KV!
Will call the engineer now I think there might be hope!
Alex
Old 04-12-2007, 12:20 AM   #4 (permalink)
JayCee,
You obviously apear to know a lot about this type of issue (guess your and engineer) and wondered how complicated it would be to replace the Line Output Transformer? I think I found the bit of kit at : http://www.signalsuk.com/signalsuk.n...C?OpenDocument
I am not a complete buffon with electrics but is this a job for the experts bearing in mind I could do with saving the call out fees etc.
Alex
Old 04-12-2007, 1:02 AM   #5 (permalink)
Conspicuous Member
JayCee's Avatar
Well, sure we're all in the same boat trying to save money but some jobs are best left to the experts.
I don't know how skilled you are with a soldering iron and if you're comfortable handling electronic components...then there's the safety issue of course...which is really the most important.
It's your call.
JayCee
Old 04-12-2007, 10:57 AM   #6 (permalink)
NST
Thanks: Gave 9, Got 48
I agree, I wouldn't recommend changing a LOPT yourself due to the high voltages that are stored inside the CRT and/ or capacitors.
NST is offline   Reply With Quote
Old 04-12-2007, 10:21 PM   #7 (permalink)
Hi Guys,
Regards
Alex
Alex check the Horizontal output transistor if good, then resolder it and a Coil that is connected to the base of that transistor,i don't know about that chassis so i can't give exact placement of those components,
silv is offline   Reply With Quote
Old 04-12-2007, 10:37 PM   #8 (permalink)
Conspicuous Member
JayCee's Avatar
silv, this is a UK/Europe-based forum and we have different TV systems and models/chassis from your side of the pond.
The components you mention generally do not not on this chassis give any trouble.
JayCee
problem, thomson
