Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Techwood Twp4210 Advice, Plus Some Repair Tips estar66 Plasma Televisions 18 08-09-2009 4:18 PM
Budget 37" Advice needed... HANNspree XV 37" JT02-E2 vs Techwood LCD37722HD shuRe LCD Televisions 1 27-06-2007 10:46 PM
Techwood ScUzLY Plasma Televisions 2 01-07-2005 4:37 PM
Are you considering a Techwood? adymartin Plasma Televisions 0 14-02-2005 1:36 PM
Techwood 42 the white rabit Plasma Televisions 0 02-12-2003 10:23 PM
Old 03-12-2007, 1:55 PM   #1 (permalink)
dsw182's Avatar
Thanks: Gave 10, Got 6
Techwood advice
I'm looking into buying a widescreen CRT, second-hand, and have come across a brand called "Techwood".
I understand that Tesco sells their kit from time-to-time and that they are similar to Wharfedale stuff but under a different badge(?). I know they are towards the budget end of the scale, but do they still deliver good value and some quality?
dsw182 is offline   Reply With Quote
Old 03-12-2007, 11:36 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
Re: Techwood advice
I don't know if "quality" is the correct word to use but they probably are value for money...if you can still find them...the supermarkets are about the only place that have them these days.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
dsw182 (10-12-2007)
Old 10-12-2007, 2:09 AM   #3 (permalink)
dsw182's Avatar
Re: Techwood advice
I ended up picking up a 28" Techwood for £40 from a local ad.
Not that I'm anywhere near an expert on the subject, but the picture quality appears to be very good.
Old 10-12-2007, 10:38 AM   #4 (permalink)
Thanks: Gave 12, Got 27
Re: Techwood advice
My brother had one of these its just died after only 2 years and had all sorts of problems ,but good luck with yours.
chrissyman is offline   Reply With Quote
advice, techwood
