Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
SONY KD28DL10U Latest software LDJ CRT Televisions 1 19-02-2005 8:29 PM
Sony KD28DL10U Inherent Problem? henchard CRT Televisions 17 01-03-2004 8:36 PM
Sony KV-32FQ70 probelm with EPG menu of Sony VTXD800 freeview box MartinM CRT Televisions 4 16-01-2004 10:46 AM
Old 28-11-2007, 8:01 PM   #1 (permalink)
Gary923
Posts: n/a
Question Sony KD28DL10U Freeview Inoperative?
Hi people, hope somebody can help me. I have just purchased a second hand Sony KD28DL10U widescreen tv with a freeview receiver built in. Unfortunately, the set did'nt come with an instruction manual. I have tuned the tv into channels 1-5 no problem, but when i press the digital option on the remote, it says 'the programmes are not stored' at the top of the screen. Just wondered if anyone had any ideas of how to get it working? Many thanks. Gary.
Old 28-11-2007, 9:04 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 859
Re: Sony KD28DL10U Freeview Inoperative?
Are you aware there are two aerial sockets and there should be a short RF cable to loop-through the signal from the digital tuner to the analogue tuner.
The aerial goes to the top aerial socket nearest the scart sockets and an RF Flylead (male to female) coax from the bottom socket to the socket to its right and above (looking from the rear).
In any case you need to retune the digital tuner to your local transmitter.
I can send you a .pdf of the setup instructions if you pm me an email address.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 28-11-2007, 9:10 PM   #3 (permalink)
Gary923
Posts: n/a
Cheers jaycee,
That would be a great help. My e-mail address is ; gcarter923@tiscali.co.uk . Many Thanks.
Old 29-11-2007, 8:11 PM   #4 (permalink)
Gary923
Posts: n/a
Thanks for your assistance jaycee, but I still can't get the freeview to operate. I have plugged the aerial in either through my dvd recorder and back to the telly, or directly to the tv. Both methods pick up channels 1-5 fine via autotune, but the freeview channels are none existent. Does this model need a freeview card, or is there a chance that it's just knackred? Thanks, Gary.
Old 29-11-2007, 8:29 PM   #5 (permalink)
Conspicuous Member
JayCee's Avatar
The aerial must be connected to the TV Aerial in socket as shown in the installation manual...you then connect your DVDR between the other two sockets as shown.
From memory I don't think you can access the digital tuning menu from the remote...strange as it sounds...these sets were an oddity.
Is there a setup button on the front...under the drop-down flap under the screen?...if there is press it and it should autotune both analogue and digital.
JayCee
Old 30-11-2007, 11:55 AM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
Further info re tuning the digital side...It is different from
the KD28DL11 and not accessed from the menus. Press the '?' button while in Digital mode and it takes you to the setup.
JayCee
Old 02-12-2007, 5:16 PM   #7 (permalink)
Gary923
Posts: n/a
Talking Re: Sony KD28DL10U Freeview Inoperative?
Just tried that and it worked straight away. Thanks very much for your help Jaycee. Much appreciated.
Old 02-12-2007, 7:10 PM   #8 (permalink)
Conspicuous Member
JayCee's Avatar
Glad to hear it
JayCee
freeview, inoperative, kd28dl10u, sony
