Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 26-01-2003, 1:09 AM   #1 (permalink)
mandingo
Posts: n/a
May someone please measure 32fx66 box?
I have read the official tv measurements, but I don't know how big the box is.
I am afraid it won't fit my lift, and don't even know if I will be able to carry it up the stairs so, may someone give me a clue?
Thanks and regards,
mandingo
Old 26-01-2003, 1:50 AM   #2 (permalink)
Thanks: Gave 11, Got 14
I can let you know tmr if no one answer before then. As I still got my box in Shed waiting to be burnt. As I kept hold of it till I decided if I am happy with my tv set. So I measure it tmr for you unless someone answer before hand.
But put it this way i got it through my door
Rookies is offline   Reply With Quote
Old 26-01-2003, 1:56 PM   #3 (permalink)
Thanks: Gave 68, Got 26
i'm just hoping the actual tv will fit through the door frame
neilybealy is offline   Reply With Quote
Old 26-01-2003, 4:39 PM   #4 (permalink)
Thanks: Gave 95, Got 75
I remember my first Sony 32"WS TV (diff model to yours) came in a HUGE box and had to take it out of it to get through my front door.
As for lifting it ....Not on your own unless you want a hernia!
Kevo is offline   Reply With Quote
Old 26-01-2003, 10:32 PM   #5 (permalink)
I can measure tomorrow for you. PM me if you need to know before.
MadAxeMan is offline   Reply With Quote
Old 26-01-2003, 10:34 PM   #6 (permalink)
mandingo
Posts: n/a
Thanks to all of you.
No, I'm not in a hurry, probably won't get the set until 2nd week of february, but I wanna plan how i will carry it to my living room.
Best regards,
mandingo
Old 27-01-2003, 6:04 PM   #7 (permalink)
Here the measuring roughly in cm's
W: 100 x H: 70 x D: 69.5
Old 27-01-2003, 9:26 PM   #8 (permalink)
mandingo
Posts: n/a
Thanks!
Now I know it won't fit my lift... I wonder how will it arrive up to my living room
Thanks again and best regards,
mandingo
Old 27-01-2003, 9:41 PM   #9 (permalink)
How many flights of stairs?
Two of you should have no problem.
Or take it out of the box.
Old 27-01-2003, 9:46 PM   #10 (permalink)
mandingo
Posts: n/a
Hi, I live in a third floor, so I suppose it won't be too difficult.
My lift is 82x75 cm., so I have just realised that even without the box I couldn't put it in there, but at least it will fit my door
Thanks and regards,
mandingo
32fx66, box, measure
