Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 12-01-2003, 12:11 AM   #1 (permalink)
HowieC's Avatar
Thanks: Gave 0, Got 3
Sony Service Menu Tip
Those of you new to sony service menus may not be aware that pressing the mute button on the remote clears the screen of all but the single adjustment you are using. Makes geometry adjustments much easier. Also the correct way to exit the service menu is to press menu to get back to the screen with TT on it and enter 00. DO NOT enter any other numbers.
I've now set up 3 32fx66s for friends all of which were badly adjusted ex-factory and all adjusted up very well.
What is going on in the Sony factory??
HowieC is offline   Reply With Quote
Old 12-01-2003, 1:45 AM   #2 (permalink)
Super Moderator
Thanks: Gave 289, Got 161
End user = Quality control.
lynx is offline   Reply With Quote
Old 13-01-2003, 11:26 PM   #3 (permalink)
HowieC
Was there a common problem with the setup of them?
I received mine on Saturday. Set up colour, contrast, brightness etc using video essentials. Geometry looked good although there is a slight left shift needed for the s-video mode.
Gonna leave for a week to see if it bothers me, then attack the service menu.
I manged to get my 29x1u pretty good a few years back.
Did you manage to get rid of the overscan?
yetiuk is offline   Reply With Quote
Old 14-01-2003, 2:46 AM   #4 (permalink)
HowieC's Avatar
Yetiuk
Mainly geometry faults, one in particular was set up incredibly badly. It looked as though someone had tried to correct a rotation error by using a combination of other adjustments - a real mess.
One looked very soft and was improved loads by dynamic convergance adj. Such a basic setting!
The overscan is adjusted simply with H-size & V-size adjustment.
Old 14-01-2003, 3:08 AM   #5 (permalink)
Fancy coming round and sorting mine out Howie
ryanos is offline   Reply With Quote
Old 17-01-2003, 10:35 PM   #6 (permalink)
TGZUK
Posts: n/a
COULD ANYONE TELL ME IF THERE IS A WALKTHRU ON TWEAKING THE SET AS I AM NOT SURE WHAT TO DO
Old 17-01-2003, 10:48 PM   #7 (permalink)
Super Moderator
First thing is knock your caps lock off.
What symptoms is your set displaying ?
Before adjusting anything spend a little time and write all the current settings down,that way if it all goes belly up you can revert to the status quo.
Old 17-01-2003, 11:17 PM   #8 (permalink)
TGZUK
Posts: n/a
tweak
no real symptoms other than when i watch sport and the camera goes to the crowd etc i get a very visible flickering,
Also do i hold down Prog _and Prog + whilst switching on to enter service menu?
Thank you for this
Old 17-01-2003, 11:52 PM   #9 (permalink)
Thanks: Gave 11, Got 14
TGZUK what tv do you have then?>
Rookies is offline   Reply With Quote
Old 18-01-2003, 12:20 AM   #10 (permalink)
TGZUK
Posts: n/a
i have a kv32fx66, would just like to see if i can improve the picture quality
Old 18-01-2003, 12:31 AM   #11 (permalink)
Super Moderator
How to Access the Service Menu
On a KV-32FX60
Turn OFF the set from the televisions on/off switch.
Hold down the two dimpled buttons on top of the television ([Prog +] and [Prog -]), and keep them depressed.
Turn the set ON from the televisions on/off switch.
After a few seconds the set will come on. You can now release the dimpled buttons.
Old 18-01-2003, 3:48 PM   #12 (permalink)
TGZUK
Posts: n/a
no buttons on top of tv only in side flap, tried holding p+ and P- whilst powering up but does nothing, any one have any clues
Old 18-01-2003, 4:07 PM   #13 (permalink)
Super Moderator
Since i don't have this set then i'm in the dark. Try 'From standby >(i)>5>+vol>tv (top left ish).
menu, service, sony, tip
