Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 11-01-2003, 7:12 PM   #1 (permalink)
hoyrm
Posts: n/a
how many RBG ports has a JVC 28R25 got?
I was looking at some reviews in the magizines and I came across two reviews on the JVC 28R25. Both these magizines said this TV had two RGB enabled SCARTs.
I thought there was only one RGB. The other two were S-Video. Is this true?
Old 11-01-2003, 7:44 PM   #2 (permalink)
Thanks: Gave 50, Got 479
The general rule with with JVC is that all 50Hz sets have one RGB input and all 100Hz sets have two. The R25 has one.
GaryB is online now   Reply With Quote
Old 11-01-2003, 8:00 PM   #3 (permalink)
hoyrm
Posts: n/a
Cheers,
I wonder how two mags got that wrong! Thought for a moment that I overlooked the 28R25
Oh well, it's back to deciding between the JVC 28T25 or the Panasonic 28PL1.
Does anyone know if you can get a SCART switching box that switches automaticaly?
Old 11-01-2003, 10:23 PM   #4 (permalink)
Does the 28T25 have 2 RGB scarts then?
saguk is offline   Reply With Quote
Old 12-01-2003, 12:11 AM   #5 (permalink)
No, the T25 is basically the same set as the R25 but without the Surround Sound and Subwoofer. It also has a more basic stand.
There is an AV-28/32X25 which does have 2x RGB inputs and is 100Hz.
Old 12-01-2003, 12:26 AM   #6 (permalink)
thamesider
Posts: n/a
This JVC model(AV-28R25EK) has, as far as i'm aware
One RGB scart input.
Two Composite signal scart inputs.
One S-video cable input.
Very good sound, dolby pro-logic (comes with a detatchable sub-woofer)
The 28T25 is the same Model, but only has Nicam stereo (no center speaker under screen, or detatchable sub-woofer)
If I can get my scanner to work, I will put up the appropiate page from the manual with all the specifications etc.....
28r25, jvc, ports, rbg
