Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 11-01-2003, 6:46 AM   #1 (permalink)
Iain Shields's Avatar
Thanks: Gave 3, Got 2
Toshiba t.v picture looks a bit green sometimes, can anyone help please?
Hello all, thanks for taking the time to read this,
I have an old(ish) Toshiba 3373DG 4:3 ratio television which seems to have a problem.
When I play some dvds from an American Pioneer DV-606D player using it's s-video output into the s-video input on the t.v. I get a very green picture from a few films but not all, but even with the film's that are mostly ok, I still find that the darker scenes have a bit of a green tinge about them. At first I thought this was a problem with the dvd player as the t.v did not seem to have this problem with any other inputs e.g. satalite or video but having since tried the player on a friends t.v (which had no problem) I now know that this is probably not the case. The Toshiba t.v supports both 443 and 358 versions of ntsc and I have tried several s-video leads, all with the same problem....
I'm out of idea's folks, can anybody think of anything else?
Thanks in advance,
Iain
Cameras:- Canon 40D + BG-E2n Grip
Lenses:- Canon 50mm f/1.8, Canon EF100-400mm L IS, Sigma 10-20mm EX DC, Tamron 28-75 XR DI f/2.8mm.
HC:- TV - Samsung PS50Q7HD Plasma, Amp - Denon AVR-1803 6.1, Speakers - B&W 600 Series fronts + Solid Monitor rears.
Iain Shields is offline   Reply With Quote
Old 13-01-2003, 12:07 PM   #2 (permalink)
Bumped
Sorry folks... but dosn't anybody have any idea's at all, anything could help
Old 13-01-2003, 12:53 PM   #3 (permalink)
Kingston LJ's Avatar
Thanks: Gave 0, Got 2
I am not sure, but it could be something to do with the GAMMA. Some tvs have gamma-correction, which is used to cure NTSC problems such as green or purple images.
I am not a pro, but I think I could be right.
Cheers!
Kingston LJ is offline   Reply With Quote
Old 14-01-2003, 2:22 AM   #4 (permalink)
Thanks for the reply Kingstonly,
There is no "gamma" adjustment in any of the regular menus, there could be one in the service menu but to be honest I'm scared of touching anything in that menu as I'm not a pro either, even then, I wouldn't know which one to adjust as they are all abreaviated (spelling? )
Could someone else possibly comment on a GAMMA adjustment for this problem or anyone who has knowledge of Toshiba service menus that could tell me which one to adjust!!!...
Thanks again Kingstonly,
Iain.
Old 14-01-2003, 1:00 PM   #5 (permalink)
j4sonk's Avatar
sure its not the hue on tv.
j4sonk is offline   Reply With Quote
Old 14-01-2003, 11:46 PM   #6 (permalink)
Iain, forget about what I said about the Gamma. I am fairly sure it is the HUE, your tv may have an adjustment on one of the menu`s. Adjusting the hue can help cure colour problems with NTSC signals, the usual problem is a green or purple tinge to the picture.
Hope I have helped.
Cheers!
bit, green, picture, toshiba
