Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-01-2003, 1:03 AM   #1 (permalink)
warranty question. Urgent help please.
im just about too order a tv online .
is it worth buying extra warranty ? 250 pounds ?
or just go for the standard 1 yr.
the tv im buying is a sony kp44px2 . (approx 1600 pounds)
what can go wrong with RP tvs and are the costly too fix ?
any quick info will be very helpful
thnx in advance for help.
F1F3R.
F1F3R is offline   Reply With Quote
Old 10-01-2003, 1:16 AM   #2 (permalink)
gringottsdirect's Avatar
Thanks: Gave 1, Got 11
Check the name of warranty provider, you may find no local service agent / dealer will honour it or be interested in helping.
If you have to return your television to the online dealer for service, expect frustration.
Domestic & General are the main providers of extended warranties and pay service agents better than average rates, so you may be luckier finding a repairer to help if it is a D & G policy.
You will also save money if you buy your warranty straight from D & G directly rather than through a dealer.
www.domgen.com
Saying all that, if you buy your tv from a mail order dealer it seems most dealers will refer you back to them for service these days. The honeymoon is over.
Whether you should buy a warranty ? Only you can decide that...
Je voudrais manger boire et baiser.
gringottsdirect is offline   Reply With Quote
Old 10-01-2003, 1:21 AM   #3 (permalink)
thnx .
i'll just check .
best regards
F1F3R.
Old 10-01-2003, 1:50 AM   #4 (permalink)
just ordered the kp44px2u with extended 3 yrs warranty..
thnx again.
question, urgent, warranty
