Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-08-2007, 10:43 AM   #1 (permalink)
Shersm
Posts: n/a
Toshiba 32ZT29B Help Needed
When I turned on my TV in the EPG there was no digital station. When I selected a terrestrial station after a few minutes, the picture switched to a blue screen and then it jumped back to show the station I was watching again.
The next time I turned the TV on, the digital stations where showing in the EPG. When I selected one of these stations the same thing happen again; jumping to a blue screen and then jumping back to the station again. However this time load of wavy lines also appeared going down my screen.
I have spoken to my local TV repair man, who I think was just guessing what the problem was; he also seemed reluctant to come out! When I first spoke to him he said about removing the teletext part. Then, when I spoke to him again he thought it was the Freeview module. I also to another TV repair person who said that a common problem with this model was the DFS module.
I would be grateful if someone could give me some advice; I don't really want to pay out over £200 on something which might not resolve my problem!
Many thanks
Old 10-08-2007, 12:33 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 856
Re: Toshiba 32ZT29B Help Needed
It could be either module causing those symptoms...but before you go any further go into the setup/tuning menu and re-scan the digital channels picking "First time installation" in case the DVB setup has been corrupted.
It it does turnout the DFS Module is at fault Toshiba will supply a free replacement module leaving you the engineers labour to pay which will be a lot less than £200
Have a read through of this thread...and also this one...all the info and contact details are there.
Good luck.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Shersm (10-08-2007)
Old 10-08-2007, 8:13 PM   #3 (permalink)
Shersm
Posts: n/a
Thanks for replying. Tried to go to the set up menu, but when I turned on the tv on first of all, it only showed terrestrial stations. There was no digital signal being received. The remote control does not work, even after replacing the batteries with new ones. Tried to go to the set up menu using the side buttons on tv, but was only able to access the picture and sound menus. After playing with the side buttons, was able to receive digital and analogue stations, however the remote control was still not working. Think I need to call a tv repair man out to have a look!
32zt29b, needed, toshiba
