Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 09-08-2007, 9:07 PM   #1 (permalink)
mitsubishi black diamond 28inch widescreen crt
the picture on the above has went small in height and width,any ideas to fix,and if dry joints which board will i check?
anth699 is offline   Reply With Quote
Old 09-08-2007, 11:06 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
Re: mitsubishi black diamond 28inch widescreen crt
You need to give the model no taken from the rear label when asking for help.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 10-08-2007, 1:41 PM   #3 (permalink)
thanks
mitsubishi black diamond..BDS 2851 WS
Old 10-08-2007, 2:30 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
Originally Posted by anth699 View Post
thanks
Have you tried changing the "mode" setting (use left/right arrow buttons) within the picture menu?
JayCee
28inch, black, crt, diamond, mitsubishi, widescreen
