Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 09-08-2007, 1:50 PM   #1 (permalink)
Thanks: Gave 4, Got 11
Toshiba 36ZP48 - Colourful Corners
We moved house last week and upon turning on the TV we noticed the bottom left and top right corners are a lot more 'colourful' than they used to be
It's as if the TV is sitting too close to a magnetic source (which AFAIK it isn't). Is this something that will sort itself out or should I be making a call to the removals company?
WhiteChristmas is offline   Reply With Quote
Old 09-08-2007, 4:53 PM   #2 (permalink)
Grumpy Old Troll's Avatar
Thanks: Gave 16, Got 79
Re: Toshiba 36ZP48 - Colourful Corners
Leave it switched off at the mains overnight and try it in the morning.
Report back......
Grumpy Old Troll is offline   Reply With Quote
Old 10-08-2007, 8:51 AM   #3 (permalink)
Thanks for replying, I will give it a whirl and let you know the outcome (might not be until later in the week though).
Old 20-08-2007, 10:25 AM   #4 (permalink)
Told you it would be a while before replying (been off for a week doing up the front room - it would have been easier being at work!).
Alas, leaving the set unplugged overnight has not resolved the colourful corners issue - any other suggestions...?
Old 20-08-2007, 11:53 AM   #5 (permalink)
It's worth getting it degaussed. A local TV engineer should be able to do that pretty cheaply, it's only a few seconds with his magic wand!
If that doesn't cure it, the set's had a knock in transit.
36zp48, colourful, corners, toshiba
