Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 08-08-2007, 8:14 PM   #1 (permalink)
Help, wine spilled into TV
I don't know if this is the place to ask, but my wife just spilled a glass of wine that went through the side vents of our Toshiba 28w93b. It started making a strange buzzing sound and I immediately switched off at the mains.
Question is, what next? Even if we leave it a few days, do you think it'd be safe to use without doing anything to it first? Unlike water, wine dries sticky, but I don't know how bad it could be. And being about 5 years old an engineer would cost more than it's worth. Not being an electrician opening up the back doesn't appeal at all with all the warnings about shock hazards. Tempted to just wait and switch it back on and hope for the best, but could that be a fire hazard?
Anyone else had similar things happen with water, kids drinks, coffee etc? Is it basically time for a new TV?
Alex
huron is offline   Reply With Quote
Old 08-08-2007, 8:20 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
Re: Help, wine spilled into TV
That's all you can do...just be ready to switch off quickly if you smell burning.
It's unlikely to go on fire...the buzzing noise you heard was probably a protection circuit kicking in due to a short circuit.
If no go you have no option other than to call in an experienced engineer to see how bad the damage is.
Your home contents insurance may cover the cost of repair/replacement.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 13-08-2007, 12:11 AM   #3 (permalink)
Thanks: Gave 4, Got 26
If the liquid has drained through and dried out the any residue will be very thin so it's very unlikely to cause any problem at all. Just turn on and the warmth should evaporate anything that remains quite quickly
cheapskate58 is offline   Reply With Quote
Old 13-08-2007, 12:40 PM   #4 (permalink)
Thanks: Gave 78, Got 17
Have a fire extinguisher nearby just in case
Xabi17 is offline   Reply With Quote
Old 14-08-2007, 1:18 PM   #5 (permalink)
Thanks: Gave 1, Got 2
Hi ya. The wine might act as a corrosive agent if you do not clean it off the circuit board and may cause problems later on. Unless you are happy to do it, get someone with the knowledge to do it.
I had a similar problem with white wine that took out the audio. I cleaned this all off and resoldered/repaired the corroded tracks.
Geoffw is offline   Reply With Quote
spilled, wine
