Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray Review
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Old 08-08-2007, 8:06 AM   #1 (permalink)
Thanks: Gave 3, Got 5
Toshiba 36ZZZP46 Retuning Question
Hi, sorry if this is a daft question but just acquired a 2nd hand 36ZP46 and want to auto-tune it. Trouble is there are no tuning options in the set up menu.
Have seen this before (on previous Tosh) when keeping menu button pressed would reveal these options but that doesn't seem to work here.
In a possibly related issue the set's response to the remote seems to vary depending on what video source it is showing! On Ext1 (Sky) it responds fine but on freeview or aerial it often doesn't respond at all and at best very sluggishly.
Any thoughts on either of these issues would be most welcome.
1050
Mr_Rick is offline   Reply With Quote
Old 08-08-2007, 9:39 AM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 859
Re: Toshiba 36ZZZP46 Retuning Question
Make sure it's on the internal tuner by pressing the AV input button, press button 1 and press Menu, right arrow until you see Setup and then the tuning options should be available...they are not usually available if the set is switched to an AV input.
The owners manual can be downloaded from herehttp://tesc.toshiba.co.uk/Web/Websit...t?OpenFrameset
You may want to edit the title and remove a couple of extra "Z"S
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 08-08-2007, 7:12 PM   #3 (permalink)
Thanks JayCee, now tuned fine.
Anybody got any thoughts on why remote is sluggish depending on input?
Apologies for the extra Zs by the way - must have been more tired than I thought this morning
36zzzp46, question, retuning, toshiba
