Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 07-08-2007, 3:14 PM   #1 (permalink)
KevIW's Avatar
Thanks: Gave 15, Got 17
36ZP48 Power switch cover broken!
Argh! The kids abuse has finally done for my power switch cover. I have found this http://www.mysparesshop.co.uk/cgi-bi...l=36zp48&part= which is what I need I think (no picture) Has anyone else had this happen to them and how easy do you think it will be to change it?
Toshiba 42Z3030 PS3 Wii Toshiba HD-EP30 Pace Sky+ Yamaha RX-V361 NS-P110
KevIW is offline   Reply With Quote
Old 07-08-2007, 3:18 PM   #2 (permalink)
Thanks: Gave 16, Got 146
Re: 36ZP48 Power switch cover broken!
Cant help but laugh. clicked on the link and the item is called knob power, childish I know, but simple things when bored at work!
Para is offline   Reply With Quote
Old 07-08-2007, 4:47 PM   #3 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
The link you gave is for the control knob for the on-off switch...the part you push to switch on/off.
As you have called it a "power switch cover" is it not the "Door Flap.control" you are after?
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 07-08-2007, 6:24 PM   #4 (permalink)
KevIW's Avatar
No it is the on off switch button cover. It is hinged at the top and has been broken by child abuse!
36zp48, broken, cover, power, switch
