Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 06-08-2007, 8:12 PM   #1 (permalink)
Sony KV-28FX20U - Is it on its last legs?
Hi!
I have the above TV and the picture keeps going a kind of green colour and then will lose it all together. The next day will be ok and then go again. Has been like this for a few months now. Thought it could be the picture in connections but have had these all checked so pretty sure it is the tv. Sound is all ok.
Tonight, the standby led on the set started flashing and according to the manual, I should be taking it to a Sony Service Centre.
I am guessing that it is going to cost a bit to take it to Sony so would welcome any ideas on what might be wrong with it and also if it needs a repair, how much I looking at giving them!
I have had it over 7 years but I don't want it to die!
Thanks for your help, Crackerdaq
crackerdaq is offline   Reply With Quote
Old 07-08-2007, 9:04 AM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
Re: Sony KV-28FX20U - Is it on its last legs?
Your symptoms could be a failing crt with an intermittent short but you really need to get it looked at by an experienced TV engineer for a definitive answer.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 07-08-2007, 6:03 PM   #3 (permalink)
Thanks - knowing nothing about repairs, is this something that is going to cost a fortune or is it relatively minor? Don't want to waste money when I could put it towards a new one.
Thanks again, Crackerdaq
Old 07-08-2007, 8:05 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
If it is a faulty crt...it'll be a write-off.
JayCee
kv28fx20u, legs, sony
