Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 01-08-2007, 1:51 PM   #1 (permalink)
Toshiba DSF Problem - Engineer reqd. in S. M/cr
I Have a Toshiba 36ZP38B (two of them in fact) and its is displaying the commonly reported symptons which have been diagnosed in this forum many times as a faulty DSF module. I have spoken to the lady at Toshiba and can get hold of a replacement by supplying my serial no. etc, etc.
The one thing I can't get hold of is an engineer who can fax Toshiba a diagnosis, accept delivery of the part and come to my home to fit it.
Please, can anyone help me?
MikePich is offline   Reply With Quote
Old 01-08-2007, 2:38 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
Re: Toshiba DSF Problem - Engineer reqd. in S. M/cr
Could the lady at Toshiba Cust services not recommend a service centre or TV technician in your area?
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 01-08-2007, 2:47 PM   #3 (permalink)
Hi Jaycee
Thanks for the swift reply.
Toshiba recommended somebody in Bolton - quite a large sounding operation. They charge £30 to collect and want to soak test it for 3 days. I would prefer to deal with somebody closer and more "friendly".
Old 01-08-2007, 3:23 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
The sets are easily fixed on-site and as long as the modules are brand new replacements soak-testing is unnecessary.
Try phoning around local TV repair shops advertising in your local newspapers or business directory, and try Yell.com or Yellow Pages.
Just explain the problem and tell them you want them fixed in your home...any decent TV engineer will be aware of this fault and cure and be able to give you an estimate for their labour.
Good luck and report back if you cannot find anyone suitable.
JayCee
Old 01-08-2007, 3:57 PM   #5 (permalink)
Success!
I thought I'd exhausted the local engineers from Yell.com.
Went a little further afield and found one who carries a DSF module as a stock item because he's done quite a few of these. Booked in for Saturday morning - £90 - sorted.
DTS Repairs in the Home - 0161 335 6223 - Simon.
dsf, engineer, m or cr, problem, reqd, toshiba
