30-07-2007, 1:25 PM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Taking a TV from England to Greece
I have a Sony KV-32FX68U and have moved from the UK where i purchased it to Greece.
I have installed the channels and i recieve perfect pictures but no sound. Someone told me i have to change a chip so i can hear the audio, is this true and if so, whats it going to cost me?
Thanks in advance...
30-07-2007, 3:19 PM
#2 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 856 | Re: Taking a TV from England to Greece Quote:
Originally Posted by zanteboy Someone told me i have to change a chip so i can hear the audio, is this true | Nope, use "Manual Programme Preset" as detailed on page 13 of the user manual and under "System" just change it from "PAL i" to "B/G" and then you should have the sound system for Greece.
If you don't have the user manual you can download it from here...enter the model no in the search box as KV-...and then you'll find your model in the list which appears...it's the last one in the list under "KV-32"
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
30-07-2007, 6:49 PM
#3 (permalink)
| | Prominent Member
Thanks: Gave 185, Got 379 | Re: Taking a TV from England to Greece
I remember well the good old days when you had to adjust the ferrite slug in a sound IF coil
Chris Muriel, Manchester
30-07-2007, 7:55 PM
#4 (permalink)
| | Conspicuous Member
Originally Posted by Chris Muriel I remember well the good old days when you had to adjust the ferrite slug in a sound IF coil  | Giving your age away there Chris
Aye...I remember it well.
31-07-2007, 12:07 PM
#5 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Taking a TV from England to Greece
Cheers Jaycee but when i go to the 'manual programme preset' menu i dont get the 'system' option come up.
31-07-2007, 12:28 PM
#6 (permalink)
| | Conspicuous Member
Originally Posted by zanteboy Cheers Jaycee but when i go to the 'manual programme preset' menu i dont get the 'system' option come up. | Page 11...set the language/country and then the system option will be available.
31-07-2007, 12:37 PM
#7 (permalink)
| | New Member
When i set the language it doesn't give me the country option!
31-07-2007, 12:43 PM
#8 (permalink)
| | Conspicuous Member
Originally Posted by zanteboy When i set the language it doesn't give me the country option! | Set the language then see if the system option is available under manual programme preset.
31-07-2007, 12:45 PM
#9 (permalink)
| | New Member
No its not....
31-07-2007, 1:32 PM
#10 (permalink)
| | Conspicuous Member
Originally Posted by zanteboy No its not.... | In that case it can only be done within the service menu...which is a dangerous and scary place for the uninitiated...one wrong button push can screw up your set.
A TV engineer local to where you are can do it...just tell them it's a KV-32FX68U (UK Model) and the "Destination" option within the service menu needs changing.
31-07-2007, 2:07 PM
#11 (permalink)
| | New Member
Cheers JayCee, appreciate your help.
