Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 30-07-2007, 8:18 AM   #1 (permalink)
Garrett's Avatar
Thanks: Gave 156, Got 416
Cool Loewe Aconda Problem/ List of Authorised Loewe Repairers.
Occasionally when switching on I hear a bit of crackling on the sound but after a short while it’s stopped anyway it not seemed to do it for about a week or more. Last night I just left the room and when I came back the TV was dead I switched on and off, the same.
I replaced the fuse and both the red and green LED light up but nothing from the screen or sound its just dead although one of the LED tried to go out but instantly comes back on.
Any one got an idea what the problem is?
Also as there not a popular make and I want it repaired on site rather then going to a repair shop is there a list of approved Loewe repairers somewhere?
Ruby Quartz Shades. Would You Rather Wear Yellow Spandex? Oh and Logan Stay Away From My Girl.
You Homo Sapiens & Your Guns. Concello Efravensa. When Will These People Learn How To Fly.
My opinions expressed here are just that, and no one else’s.
Garrett is offline   Reply With Quote
Old 30-07-2007, 10:07 AM   #2 (permalink)
Chris Muriel's Avatar
Thanks: Gave 185, Got 379
Re: Loewe Aconda Problem/ List of Authorised Loewe Repairers.
Linnisght could probably advise you of a local repairer.
Linnsight (Loewe's UK agent) used to be on 08000 27 64 65
Chris Muriel, Manchester
Chris Muriel is offline   Reply With Quote
Garrett (30-07-2007)
Old 30-07-2007, 10:10 AM   #3 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
The set is starting up finding a fault and dropping back to standby which is caused by the protection circuit to save further damage...it's not a D-I-Y fix.
The Loewe support page is here.
If you contact them they can maybe suggest a service centre in your area.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is online now   Reply With Quote
Old 30-07-2007, 10:42 AM   #4 (permalink)
Garrett's Avatar
Cool Re: Loewe Aconda Problem/ List of Authorised Loewe Repairers.
Thank I e-mailed them but as you put a number up I used it and they recommended me a repairer although from the area dialing code it looks as though thay are about 20 miles away
Old 30-07-2007, 12:47 PM   #5 (permalink)
Conspicuous Member
JayCee's Avatar
That's not too bad.
I could fix it for you if you were in Lanarkshire
JayCee
aconda, authorised, list, loewe, problem or, repairers
