| Re: Dual CRT from Asda Keycode Quote:
Originally Posted by projectogirl01 Does this mean it will not work, Can i reset it??? | What does the user manual say about it?
Have you tried the most common default codes?...0000, 1234
Most "Dual" branded sets use Vestel chassis so if you cannot reset it report back with all the letters/numbers etc printed on the rear of the set...look for any starting with "AK" followed by 2 numbers.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
