| Re: "Hidden Inch" Samsung Quote:
Originally Posted by Mofoman IT concerns tv's that when you used to watch them(4:3 set's), they had tiny half inch black borders at the bottom and top of the screen. | Nope, that's 14x9 on a 4x3 crt...the hidden part the article refers to is at the top of the frame beyond your vision on a properly setup crt and the dancing teletext lines can be seen if you reduce the height.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
