| Re: Philips 14PV330 keeps switching off
It sounds like the line output transformer arcing over which is pretty common.
I suggest you do not use it in this condition...if you call in an experienced engineer there is a chance the transformer can be replaced at an economical price...if you continue to use it in this condition it will proably destroy other components leading to a bigger repair bill or make it uneconomical to repair.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
