Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 04-12-2002, 10:33 AM   #1 (permalink)
dawogboro
Posts: n/a
Toshiba 50WT29 R TV
Does anyone know how to get into the service mode of this TV. I am experiencing some certical geometry problems and would appreciate any help/suggestion.
ANy other menu available would also be nice to know.
Many thanks
Old 04-12-2002, 5:22 PM   #2 (permalink)
Thanks: Gave 1, Got 3
Hey
I am not sure, but you can try this.
first you put on the tv,then you press MUTE one your remote one time .
The second time you press MUTE you hold it and you press on your tv MENU and you let them both lose.
press MENU once more ,and you are in the menu.
If you are in the menu you are on your own.
But be carful if you change anything that you write down de settings before you store anything,so you can put the settings back as they were.
mvrg,
raymen
mvrg.raymen
raymen is offline   Reply With Quote
Old 05-12-2002, 10:13 AM   #3 (permalink)
dawogboro
Posts: n/a
Thanks Raymen, will give it a got tonite.
50wt29, toshiba
