I've had my FQ75 for awhile now. Although, I can locate the SB's on certain dark scenes if I really look for them, I've no compliants (so far) about my set. However I think the severity of the problem varies from one particular set to another.... If you can be certain that you can live with any shortcoming of the individual set you get then I'd reccomend it.
The suggestion of buying a cheaper set if you're upgrading makes sense though...
Yummy Fur
Eternal is the warrior who finds beauty in his wounds......
