Hi there screemer.
I have the phillips 32/9527, i have been impressed with it, the picture is very good, on both dvd/cable/terrestrial channels, also the sound is quite good with good bass.
The only problems I have come across, are the dark bars down the right and left of the screen, there have been numerous threads on this, I think it can be solved by the use of a ferrite ring, I am contacting comet to send someone out to have a look at mine.
There is slight artefacting and shimmering on the picture, but not too often, I can put up with this for the picture quality.
I also have a problem when playing dvd through scart ext1, you could here terrestrial tv sound, think this is AV Crosstalk.
Cant comment on the fx66, i did look at it before i got my phillips. There will be a few threads on this forum about this tv.
Hope this helps a bit.
