Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-11-2002, 8:25 PM   #1 (permalink)
Free!!
I wish TV's were free!
But.. while your here i need some help.
I asked about adding a sub to a PL4 but didn't think it was poss.
I went to comet today to have a look at some sets and spotted the PL4 in the corner... I had a look around the back of it and spotted 2 phono sockets and a bunch of speaker grip clips.
What i want to know is what are they all for? i'm guessing the speaker clips are for the 2 rear speakers but what are the phono's for? are they incase you want to add new front speakers? if so could i run the sub from one of those channels or is it internal or external not both??
The_blue is offline   Reply With Quote
Old 10-11-2002, 8:48 PM   #2 (permalink)
Greg's Avatar
Thanks: Gave 99, Got 752
Don't know what a PL4 is but usually on TVs the two phono sockets are for taking the audio from the TV to an amp.
Where the phonos red and white?
Also does the PL4 have any DTS or DD 5.1 decoder in it? If not then I don't know how you would get the .1 signal to the subwoofer. Perhaps someone else can clarify this.
Greg
Greg is offline   Reply With Quote
Old 10-11-2002, 9:08 PM   #3 (permalink)
Thanks: Gave 0, Got 2
you can download the manuals for all Panasonic's TVs here:
http://www.panasonic.co.uk/downloadcentre/default.asp
Just enter the model number and then download the one you want [quite a hefty download though!]
Alan D is offline   Reply With Quote
Old 10-11-2002, 9:47 PM   #4 (permalink)
They are red and white, and it's dolby pro ligic but it's not got a sub out on the rear
Does it need to have a special sub out? or will the sub filter etc its self?
Old 10-11-2002, 10:04 PM   #5 (permalink)
Super Moderator
Thanks: Gave 289, Got 161
You won't get an LFE channel,but if you wish to use a sub you are likely looking at adding an amp or rec and powering the sub from there.
Opinions given are my own and are not associated with avforums.
lynx is offline   Reply With Quote
Old 12-11-2002, 7:13 PM   #6 (permalink)
LFE?
The sub i'm looking at is amped so is that ok?
Old 12-11-2002, 7:28 PM   #7 (permalink)
kelvin's Avatar
Thanks: Gave 35, Got 31
LFE is the ".1" in Dolby Digital and DTS surround formats and refers to the Low Frequency Channel - i.e. the bass channel for soundtracks.
As Lynx says, in order to run a Sub you realistically need to use a seperate receiver which will decode the sound and send the right information to the sub and other speakers - regardless of whether the sub is powered or passive. You could get away with using a stereo amplifier, in which case you would connect the 2 phono's from the back of the TV to an "aux" input on the amp, and then connect the sub in between the amp and speakers using high level (speaker cable based) connections.
I'm guessingn also, that you could get away with connecting the phono's from the TV, to the line inputs on a sub and then use the subs internal xover to extract the relevant information but I can't imagine it will sound too brilliant, and it would be VERY difficult to setup.
Hmmm - just read that back and it doesn't sound particularly understandable... hope you can get the general gist... it's been a long day!!
Kelvin
My Flickr <-- A bit empty at the moment but i'm working on it!
Canon EOS 400D + Kit Lens
New Toys(!) - Canon EF 50mm F1.8 II & Sigma 55-200 F4-5.6 DC
kelvin is offline   Reply With Quote
free
