Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-04-2007, 10:55 AM   #1 (permalink)
Help - Samsung WS32Z419D power on fault.
I have a got hold of a cheap Samsung WS32Z419D that has been damaged and am looking to get it repaired. The problem is that when powered on from standby there is a fairly loud scratchy sound for about 2 seconds then the tv powers off.
The tv looks as if it has been damaged in transit as there is some minor cracking to the case..
Does anyone know what the power on fault might be?
andygt is offline   Reply With Quote
Old 10-04-2007, 11:12 AM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 856
Re: Help - Samsung WS32Z419D power on fault.
The TV starts up discovers a fault and the "scratchy sound" is the set tripping off.
As you suspect the set has been damaged in transit it is impossible to give an accurate diagnosis without inspection...it could be minor...a break in the circuit board...a dislodged high voltage transformer lead or it could be major...a broken crt neck.
You have no alternative other than get it looked at by a competent TV engineer.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is online now   Reply With Quote
Old 10-04-2007, 11:21 AM   #3 (permalink)
Thanks for the reply - i will get it checked out this week by the local tv repair shop. Was just checking it wasn't a known fault with a simple fix.
Old 11-04-2007, 9:01 AM   #4 (permalink)
Thanks: Gave 2, Got 39
Hi Andy
WElcome to the forums and congratulations on your purchase, the Samsung is a nice tv with a little tweaking.
The problem, is probably just a damaged circuit board. Was the Tv bought new, by that I mean, could you not just get the reciept from where you bought it, and then say it was dmaged during transit, and the company does not warranty the tv, and then call Samsung and execute your warranty with them. That could potenially save you a fortune.
Just a thought, as I done this with a trintron before that got damaged in transit,( nudege, nudge,wink, wink,lol )
and Sony fixed the tube, and replaced the casing. All I had to do was present them with the receipt from where I bought it, and no one else had done the warranty, so the serial number was clean.
Mofoman is offline   Reply With Quote
Old 11-04-2007, 1:19 PM   #5 (permalink)
I got the tv from a local warehouse which deals in shop soiled white goods but had to take a pallet of damaged lcds as part of one of their deals. The samsung was the only crt and the only tv with minor case damage and it's screen intact so i thought it was worth a try for £25.
So unfortunately no receipt but i did get the manual and remote thrown in!
fault, power, samsung, wsd
