09-04-2007, 9:54 AM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Phillips 32PW9527 Problem
Hi all
Turned on my Phillips 32PW9527 this morning and it seems to of developed a proplem over night.
Every couple of minutes there is a poping sound followed by the screen going black for a second,then the picture comes back
Any Idea's
Dave
09-04-2007, 3:25 PM
#2 (permalink)
| | Member
Thanks: Gave 3, Got 3 | Re: Phillips 32PW9527 Problem
Have a search for "painter chip" which is a common fault in Philips CRT's, I discovered this after my 28" Philips started doing strange random things.
09-04-2007, 3:55 PM
#3 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 857 | Re: Phillips 32PW9527 Problem Quote:
Originally Posted by Nawty Have a search for "painter chip" which is a common fault in Philips CRT's | The OPs model uses a different chassis and doesn't use the infamous Painter chip.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
09-04-2007, 4:14 PM
#4 (permalink)
| | Member
Ahh, cool |
09-04-2007, 6:05 PM
#5 (permalink)
| | Ex Member
Thanks: Gave 0, Got 6 | Re: Phillips 32PW9527 Problem Quote:
Originally Posted by Nawty Ahh, cool  | What chassis is it?
The chassis number should be below the model No.
e.g. SA10 or Lo1.1E
09-04-2007, 7:05 PM
#6 (permalink)
| | Conspicuous Member
09-04-2007, 7:19 PM
#7 (permalink)
| | Ex Member
Originally Posted by JayCee Neither, it's an EM5E. | Hi JayCee,
Thanks just wondering
Good chassis Shame about the TUBE.
When it breaks down tends to Blow everything on the Tubebase and Line o/p
Not to forget the Line o/p Transformer. |
10-04-2007, 9:03 AM
#8 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Phillips 32PW9527 Problem Quote: |
| Hi JayCee
Turned the Tv back on after a couple of hours yesterday and it is not doing in now.My Son said it has done it in the past so do you have any idea's for this intermitent fault.
Still have a few months left on the warranty so if it could be something expensive I would like to get it sorted
Yes mine is a EM5E.
Dave
10-04-2007, 9:54 AM
#9 (permalink)
| | Conspicuous Member
Originally Posted by barney11 Still have a few months left on the warranty so if it could be something expensive I would like to get it sorted | I personally haven't worked on this chassis but intermittent shorts in the crt are common on most Philips crts and I would keep a close eye on it and get it checked out under your warranty.
10-04-2007, 10:11 AM
#10 (permalink)
| | New Member
OK thanks
cheers
Dave
