Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 06-04-2007, 7:13 PM   #1 (permalink)
Sound Problems!!
hi i have a beko 21k194ns which is 21inch.i have a xbox and a ps2 connected to it and when i play on both of them,there is no sound coming out of the speakers.Even on high volume
any help would be helpful
Kieran55 is offline   Reply With Quote
Old 06-04-2007, 7:59 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 856
Re: Sound Problems!!
You need to tell us how they are connected to the TV?
By RF? (Aerial socket), via the red/white/yellow phono connectors?, or by scart?
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 06-04-2007, 8:16 PM   #3 (permalink)
its connected with the red/white/yellow connecters with a scart connector
Old 06-04-2007, 8:32 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
You have the picture, but no sound?
These scart connectors can be input or output...you may have the wrong one or it may not be fully plugged in.
The switchable type are better.
JayCee
Old 07-04-2007, 6:32 AM   #5 (permalink)
What do you mean by switchable type?
yes just the picture,no sound
Old 07-04-2007, 12:56 PM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
This type
JayCee
problems, sound
