Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 05-04-2007, 8:41 PM   #1 (permalink)
Thanks: Gave 29, Got 25
Tosh 36zp38 Problem - Magenta/cyan over moving images
My Tosh has seemd to have picked up a bit of an annoying problem, it seems as though certain items of teh screen are highlighted in pink or blue. This happens on nearly ever channel, and it is a problem with the crt as i Have tested all the inputs individually.
The picture below is a classic example, does anyone know what it could be?
Dej
Tosh 36zp38 Problem - Magenta/cyan over moving images-image_005-small-.jpg.jpg
dej23 is offline   Reply With Quote
Old 05-04-2007, 10:11 PM   #2 (permalink)
Thanks: Gave 0, Got 6
Re: Tosh 36zp38 Problem - Magenta/cyan over moving images
Dej
Looks like interferance of somesort poss Tuner/ I.F stage fault?
Not sure?
Have you replaced the DFS board (DigitalModule) Very common problem with these Tosh models (pic faults).
Try replacing the MDFS 03 (CAN MODULE)also check dry joints on TUNER and I.F module.
Let me Know!
Medusa is offline   Reply With Quote
Old 08-04-2007, 10:43 PM   #3 (permalink)
Cheers, I haven't replaced anything at all yet.. WIll look in to it in more detail during the week.
Old 09-04-2007, 12:14 AM   #4 (permalink)
Chris Muriel's Avatar
Thanks: Gave 186, Got 379
If it's a tuner fault, using an input from a DVD player connected by SCART should see the problem disappear
(as a simple test).
Chris Muriel, Boston (normally Manchester)
Chris Muriel is offline   Reply With Quote
Old 14-04-2007, 10:32 AM   #5 (permalink)
This seems to be a digital processing fault as this happens via scart (sky) as well. But the TV has got worse, it now switches it self off!
Old 14-04-2007, 11:34 AM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
In that case it could be the DFS module discussed here
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 14-04-2007, 12:20 PM   #7 (permalink)
Cheers Guys
36zp38, images, magenta or cyan, moving, problem, tosh
