Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 05-04-2007, 11:11 AM   #1 (permalink)
Thanks: Gave 6, Got 4
lg crt replacement remote needed
my dog has just chewed at the casing of my LG CRT TV (RI-28CZ10RX) remote control... he doesnt seem to have chewed aything but the casing though (ie none of the workings seem damaged in any way) but now it doesn't work and i cant change AV channel etc without it so have a problem...
does anyone know where i can buy a replacement? id either like the same axact remote or something really small (this one is really long).. it doesnt even need the number keys on it coz i dont use terrestrial broadcasts so have no need for those keys...
any ideas? has anyone had to do this before? or has anyone got an old one of these tv's knocking around with a working remote that they'd like to pass on to a good home?
thanks all
bunyboy is offline   Reply With Quote
Old 05-04-2007, 1:04 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
Re: lg crt replacement remote needed
Entering "RI-28CZ10RX Remote" in to Googles search field brings up plenty of sites where you can buy a replacement.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 05-04-2007, 2:45 PM   #3 (permalink)
you're right... thanks!
but id still rather have an exact replacement rather than one of those generic remotes that'll work with 20 different tv's.. either that or something nice and small that does what i need it to do and nothing more!
Old 05-04-2007, 3:00 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
The first Google result that appeared with my search brought up Telepart...if you click on Remote controls at the top of their page and enter "RI-28CZ10RX" it leads to a page with the exact replacement and a pattern remote for your model.
JayCee
crt, needed, remote, replacement
