Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 03-04-2007, 7:19 PM   #1 (permalink)
iybyisyl's Avatar
Thanks: Gave 8, Got 8
Toshiba 36ZP38
Hi, Im not sure but..?
Whilst watching TV tonight, the picture became unstable, juddering and joggling all over the place. At first I thought it was my Nokia box(221T) so turned that off and moved from terrestrial channel to terrestrial channel, issue was still there, very jerky pictures, kind of like the "Talkies" very staggered movements. I turned the TV to standby,and then came back to it about half an hour later. Its fine now. Is this the dreaded Scan Module issue starting ?
Thx
iybyisyl is offline   Reply With Quote
Old 03-04-2007, 7:35 PM   #2 (permalink)
Conspicuous Member
Abbeygoo's Avatar
Thanks: Gave 963, Got 1,113
Re: Toshiba 36ZP38
sounds like it!
have a search on this forum and you'll find loads of useful stuff. I rang Tosh customer care on 01159 766958 and they sent me a replacement part free of charge! They will send the part direct to an approved repairer - should cost you around £70/£80 to sort it out being fitted...... worth it though, that TV is a belter!!
Steve
Abbeygoo is offline   Reply With Quote
Old 13-04-2007, 7:33 PM   #3 (permalink)
iybyisyl's Avatar
Re: Toshiba 36ZP38
Hi, thx for responding. Did as you said today, phoned Toshiba and to be fair they were as good as gold, no resistance, sending part to my repairer, should be there sometime next week so the kind lady said. Wasn't bullish on the phone to them, went about it really softly softly, said "I was hoping you might look kindly on me, and send me the part as its a recognised manufacturing fault" > to make it even better, my repair man has quoted me £40 + VAT, so <£50 TVs back to its brilliant best. Fantastic: thx once again
36zp38, toshiba
