03-04-2007, 5:35 PM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | How 2 access Service menu for Samsung 29" Slimsfit - CS-29Z40 model?
How do i access the service menu for the Samsung CS-29Z40 Slimfit TV? I Tried Mute 1 8 2 power but didnt work.
Ne suggestions?
Regards
Satpal
03-04-2007, 9:18 PM
#2 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Service menu for Samsung 29" Slimsfit - CS-29Z40 model?
Info - Menu - Mute - Power on worked for me but i switched on the XRAY in the service menu & now the TV switches on & switches off in 3secs  .
Is there a way 2 reset it or do i need 2 call the engineer?
regards
satpal
03-04-2007, 9:40 PM
#3 (permalink)
| | Ex Member
Thanks: Gave 0, Got 6 | Re: Service menu for Samsung 29" Slimsfit - CS-29Z40 model? Quote:
Originally Posted by satpal123 Info - Menu - Mute - Power on worked for me but i switched on the XRAY in the service menu & now the TV switches on & switches off in 3secs  .
Is there a way 2 reset it or do i need 2 call the engineer? | You should all be very carefull when ENTERING SERVICE MODES and adujusting any Manufacture settings
With out any backup information.Allways NOTE settings before any changes!
Try service mode again in STAND/BY.
There is normally a FACTORY RESET with Samsung TV's but you need to get in service mode first.
At present i can only think of replacing the EPROM.Good Luck!
03-04-2007, 10:09 PM
#4 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Re: Service menu for Samsung 29" Slimsfit - CS-29Z40 model? Quote:
Originally Posted by Medusa You should all be very carefull when ENTERING SERVICE MODES and adujusting any Manufacture settings
At present i can only think of replacing the EPROM.Good Luck! | As soon as the Service Menu displays, the TV switches off  so this means i have 2 call an engineer *Sigh*
03-04-2007, 11:18 PM
#5 (permalink)
| | Conspicuous Member
Thanks: Gave 120, Got 857 | Re: Service menu for Samsung 29" Slimsfit - CS-29Z40 model? Quote:
Originally Posted by satpal123 As soon as the Service Menu displays, the TV switches off  so this means i have 2 call an engineer *Sigh* | That's why service menus are hidden.
You have knackered what was probably a perfectly good set.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4 |
04-04-2007, 2:53 PM
#6 (permalink)
| | Member
Thanks: Gave 2, Got 39 | Re: Service menu for Samsung 29" Slimsfit - CS-29Z40 model?
Why the hell would you switch on the Xray function, and more to the point, what the heck were you doing in the service menu, if you had no idea what you were going into change. That is sheer lunacy, and with turning on that option, any engineer will now know what you have done, and you will have voided your warranty.
Going into change the geometry is one thing, but playing about with setting's when you do not know what they do...I mean, why??? |
04-04-2007, 6:30 PM
#7 (permalink)
| | New Member
Ya i know i have messed up the setting....i just wanted 2 fix the geometry which i did & i started 2 check the other options...damn y did i enable the xray option...  ...so is there ne way i can reset it or will the engineer come and do it? Hope he doesnt find out that i was fiddling in the service menu
04-04-2007, 7:36 PM
#8 (permalink)
| | Ex Member
Originally Posted by satpal123 Ya i know i have messed up the setting....i just wanted 2 fix the geometry which i did & i started 2 check the other options...damn y did i enable the xray option...  ...so is there ne way i can reset it or will the engineer come and do it? Hope he doesnt find out that i was fiddling in the service menu | Now that you know what this means
If it is in warranty don't say anything? "just went off"  (This is not advised by this Forum)
If not under warranty then tell the TRUTH NOTHING BUT THE TRUTH!
The Engineer will save time looking for faults that are not there!
Good Luck!
05-04-2007, 7:30 PM
#9 (permalink)
| | New Member
Its under warranty...its a week old tv lol
09-04-2007, 6:05 PM
#10 (permalink)
| | New Member
Thanks: Gave 1, Got 0 | Re: Service menu for Samsung 29" Slimsfit - CS-29Z40 model?
Hey Satpal,
Off the topic, sorry about that.
I am planning to buy a HDTV, the two choices are:
1. samsung CS-29Z40
2. philips 29PT8836/94
how is u r TV doing any problems with the color, sharpness etc, is DNie a good addon to have. Have read in a couple of forums, about ppl asking about the settings to disable the DNIe feature. Your comments please.
09-04-2007, 7:07 PM
#11 (permalink)
| | Conspicuous Member
Originally Posted by jkunal Your comments please. | I don't think he'll have any as he broke it.
09-04-2007, 7:38 PM
#12 (permalink)
| | Ex Member
1. samsung CS-29Z40
Thanks | There might be some advice on: Do not ENTER SERVICE MODES
It was a good job it was under warranty.
10-04-2007, 3:23 PM
#13 (permalink)
| | New Member
Good news friends...I finally got it replaced with a new 1  Now i aint gonna enter the Service menu again lol
10-04-2007, 3:31 PM
#14 (permalink)
| | New Member
1. samsung CS-29Z40
Thanks | samsung CS-29Z40 has DNR and it can be enabled or disabled from the User Menu. Over all color, Sharpness, brightness is gud, only has some slighty geometry probs not much noticable though. Sound is also gr8.
I have seen the Philips 29PT8836/94 it has gud quality picture but sound could had been better. Over all its a gud TV, expensive than Samsung though.
