Just bought an xbox 360 which seems to run off PAL 60 for the most part...the problem is when I switch the display on the xbox from PAL 50 to PAL 60 my philips 28PW9509 can't handle it - all I get is a block solid flashing screen....
I've tried connecting to the xbox using the scrart lead into the RGB ports (which according to the manuals are EXT1 and EXT3) but to no avail...
