Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 23-09-2002, 4:37 PM   #1 (permalink)
mnm
Which SONY is better for a home cinema?
Which one is better for a home cinema system and why?
1)sony,34'' , fd trinitron , wega , HDTV model:KD-34xbr2
2)Sony , 57'' , high defination PJTV model:KDP-57xbr2
3)Sony , 34'' , Plasma wega flat panel mosel:KZ-32TS1
and what is yuor suggestion abou a TV for home cinema sysytem
mnm is offline   Reply With Quote
Old 23-09-2002, 6:53 PM   #2 (permalink)
Posts: n/a
I think you will find that most members of this Forum are UK based, and will probably not be familiar with those sets
Old 02-10-2002, 7:54 AM   #3 (permalink)
mnm
hi,
what is your suggestion about a tv for home cinema with a range of price between 2000$ to 3000$
Old 02-10-2002, 8:11 AM   #4 (permalink)
rct
rct's Avatar
Although, as Party Animal said, we're mostly UK based so aren't famililiar with the TVs in question. I can offer some general advice though...
This assumes all the TVs ar 16:9 and not 4:3 models
If the TV is going to be used for mostly regular TV viewing as well as occasional home cinema use, go for the direct-view TV.
If you'll be watching the set in a darkened room and in general only with films... go for the rear-projection set.
If you'll be using it mostly for films, but occasionally regular TV viewing and you are sensitive to things like purity, geometry and convergence errors, go for a plasma display. In the UK at least the screens with the best reputation are Panasonic and Toshiba.
For further help and info more specifically related to the U.S. market, you could try here . Good luck with your system
"In three words I can sum up everything I've learned about life: It goes on." Robert Frost.
Volunteer your PC and fight cancer! http://www.grid.org/projects/cancer/
rct is offline   Reply With Quote
Old 02-10-2002, 10:30 AM   #5 (permalink)
MartinImber's Avatar
Thanks: Gave 13, Got 24
What does the instring operator have to do with price.
Also 2000 $ 3000 is invalid - you need character strings
"x" $ "abcdx" is .T.
"e" $ "adcdx" is .F.
Martin - Sony KDL46W4500, STRDB930, SLHF950 SuperBeta, Pioneer 575, Castle Pembroke, Keep, & Clydes, Pace Twin PVR, BTVision. Sony TRV33 video camera. PS3
MartinImber is offline   Reply With Quote
cinema, home, sony
