Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 23-09-2002, 11:27 AM   #1 (permalink)
MaxRelax
Posts: n/a
Sony KV28LS60
After much research, and having read the broad scope of advice and information presented on this website, I finally purchased a Sony KV28LS60 last week.
A quick review for those that are interested:
To begin with you have to construct the stand. This is a very solid well designed stand, which should take you less than an hour to put together, comes with full photo instructions, and all you need is a screwdriver.
The TV is too heavy to lift out of the box, so you have to cut the front section of the box out, and slide the TV out.
It's a big TV, approx 50kg, and you will probably need help lifting it onto the stand. Sony have even stuck a diagram, showing how two people should lift the TV, to the TV.
Plugged my Pace Digibox, with Telewest, and my Playstation 2 in the back, switched it on....
Good picture at first, but after 5 mins of tinkering with the contrast and sharpness, with the on screen menu, got it just right, and now a fantastic picture. Everybody has different visual acuity, and you have the ability to really tweak the TV to your exact requirements, this also applies to the audio as well.
What I found important is the quality of the channel/programme you are watching, the poorer the quality, the more you'll probably notice on this TV. Airwolf on Bravo does not compare to a widescreen movie on BBC1.
Played some DVD's through my PS2, and the picture and sound quality are both amazing, I'm sure a dedicated DVD played would improve on that.
Also played some PS2 games, and they also look and sound great.
And finally some music cd's, which also sounded very good.
Some of the issues raised in other threads:
100hz - once you've tweaked your TV, and you've got a good signal, i.e. digital TV, DVD, the picture quality is excellent.
Horizontal scrolling text - watched a programme with this the other day, and could read it quite easily.
Football - no problem watching the footy.
Overall, the stand looks good, the TV looks even better, the on screen interface is easy to use, and finally the video and audio are impressive.
Old 23-09-2002, 12:37 PM   #2 (permalink)
rupbert's Avatar
Thanks: Gave 25, Got 19
Cheers Max, reviews like this are a good way for real users to decide which TV will give them good results.
Obviously seeing them for yourself is much better...
rupbert is offline   Reply With Quote
Old 23-09-2002, 2:59 PM   #3 (permalink)
Squirrel God
Posts: n/a
Nice to see yet another member is happy with their LS60
Old 23-09-2002, 3:01 PM   #4 (permalink)
lentini's Avatar
Thanks: Gave 4, Got 263
...and it's all down to you, Mr. Squirrel God
AVForums Guitar Hero III Tournament Winner 2008
The Maybe Elvis Toenail - '1,000,000,000 fans can't be wrong....'
lentini is offline   Reply With Quote
Old 30-09-2002, 4:04 PM   #5 (permalink)
hi there,
I just got my ls60 and i noticed one thing...when the tv is on..the stand by led is not green..but when its off the led is red...
I thought this was wierd...as on the 32 inch version of this tv the led is green when the tv is on...do i have a faulty led or is this normal on the ls60?
thanks
Alex
aa21 is offline   Reply With Quote
Old 30-09-2002, 7:11 PM   #6 (permalink)
MaxRelax
Posts: n/a
My KV28LS60 is on at the moment, and the LED is not lit.
On stand-by there is a red LED.
I prefer it this way, don't need a bright LED to tell me that my TV is switched on.
Hope that helps.
Old 01-10-2002, 8:14 AM   #7 (permalink)
phew....now i can relax and enjoy my 100% prefect tv
Thanks dude
Old 01-10-2002, 8:50 PM   #8 (permalink)
Thanks: Gave 1, Got 3
Thanks for the review I've been considering a 28LS60 - you guys think its worth spending the extra cash for a 28FX65 (£650)?
I still havn't figured out what the LS, FX etc stand for
Kuni D is offline   Reply With Quote
Old 01-10-2002, 9:36 PM   #9 (permalink)
no probs.
I really recomend the ls60, like i say, its fantastic, absolutly nothing wrong with it, and prcdirect delivered it the next day i ordered it
I think the FX is the older model version of the ls60 aint it? i am not 100% sure about that..i think feature wise they are the same though..just that the ls60 is a newer model
Old 01-10-2002, 9:53 PM   #10 (permalink)
Squirrel God
Posts: n/a
LS and FX just refer to the style of case.
FX and LS are not related models and have many different features, e.g. FX65 has 100Hz digital plus whereas LS60 is just plain 100Hz (which I prefer). Sadly, there have also been reports of the scrolling bar hidden feature on the FX models. Latest FX is the FX66. Latest LS is the LS65.
Old 01-10-2002, 9:56 PM   #11 (permalink)
Sony 28LS60
Sony 28FX65
Sony 28FX66
As mentioned, I don't really understand what the difference is between LS, FX, FQ apart from the look.
The FX66 seems to have replaced the FX65, but I don't see any differences TBH - hell they even look the same. Just a big price difference
Old 01-10-2002, 10:01 PM   #12 (permalink)
Thanks for clearing that up - you couldn't expand on why you prefer 100hz over 100hz digital plus? Also (ignorance shown) what do ya mean by "reports of the scrolling bar hidden feature" thanks.
Old 02-10-2002, 12:21 AM   #13 (permalink)
Squirrel God
Posts: n/a
Extra digital processing can introduce various artefacts into the image, especially with lower quality sources like digital TV broadcasts. It also can produce a much "harsher" image which I don't like personally as it seems a more "artificial" and "less natural" image to me.
Sony TV Scrolling Bar Problem - Official Response from SOny UK at last !!!
Old 02-10-2002, 2:05 AM   #14 (permalink)
thanks - do you know if the "scrolling bar" problem's been fixed on the FX66?
kv28ls60, sony
