Originally posted by andymh Any kit you can recommend if I go down the DD5.1/5spkr/receiver route ?? I've seen a few on EmpireDirect for around the £300 mark ? |
Other members will be able to offer advice there Andy as I don't use an amp myself, just the virtual surround on my TV, so cannot speak from much experience.
Your best bet would be to start with a search of relevant posts on the forum as many other members have been in the same predicament as yourself so there should be lots of threads and posts offering recommendations.
Also, if you search for a particular amp that you are thinking of buying, you will almost always find lots of advice about it here.
If, after searching, you cannot find the info you're after, then your best bet is to start a new thread in the appropriate part of the forum
