Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 23-01-2007, 11:59 PM   #1 (permalink)
Thanks: Gave 40, Got 35
Sony KV-21LS30 Auto Widescreen
Is there any way to stop the TV from automatically switching the display to 16:9 from anything connected to the RGB scart?
For instance when I switch on my Playstation 2 the picture is squashed (16:9) despite the game nbeing played being 4:3.
Thanks.
Eiji is offline   Reply With Quote
Old 24-01-2007, 12:16 AM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
Re: Sony KV-21LS30 Auto Widescreen
Pin 8 carries the widescreen switching signal.
Take a look at http://en.wikipedia.org/wiki/SCART
Try cutting the cable connection to pin 8 of the scart lead or it is sometimes easier to push in the pin to the body of the plug with a pair of narrow-ended pliers.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 24-01-2007, 1:24 AM   #3 (permalink)
Would it be safe and ok to just cover the pin with a thin piece of selotape?
Also, is there any method to buff out a deep-ish scratch on the silver plastic surround of the TV?
Old 24-01-2007, 11:26 AM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
I think you may have problems getting the plug in the socket if you try to insulate it as the pins are a tight fit, best just to push the pin in.
Sorry, can't help re the scratch.
JayCee
auto, kv21ls30, sony, widescreen
