Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 23-01-2007, 6:11 PM   #1 (permalink)
34HD82 lighter strip down center of screen
I have a Toshiba 34HD82. It's a couple years old, outside of the warranty. As soon as I got it, I noticed a lighter strip about 1inch wide running directly down the center of the screen. It is most prominent, or most noticeable on moving, single color images- a camera pan across a green golf course or football field or blue sky for example.
I called Toshiba and they had some service guys come out who said they couldn't see it but would take it to the shop to look at it. Unfortunately, that was going to take a month or more and we were about to move at the time, so nothing has been done with it.
I know others have experienced the same problem with this set, but I've never seen an explanation of what's causing it. Does anyone have an idea? Any clue if it's something that could be fixed for cheaper than a couple hundred? I've read that people have had a similar problem around the edges of screens and that loosening some screws on the tube a turn can correct it. Is that something I should give a try? Thanks.
thelonghop is offline   Reply With Quote
Old 24-01-2007, 5:35 AM   #2 (permalink)
Re: 34HD82 lighter strip down center of screen
bump
Old 24-01-2007, 8:58 AM   #3 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
I suspect you are not in the UK/Europe which this forum mainly caters for.
Try http://www.avsforum.com/ where I'm sure you'll get some answers.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
34hd82, center, lighter, screen, strip
