| Re: LCD or CRT
Hi Mike, i went through the same process in October, fretting over whether i could get an lcd to match my crt's picture. ..
i settled on a sony 32v2000 which you might get at your budget.. it equals my crt in all areas apart from black level and exceeds it in others with good dvd's
sky sd is very watchable on it also
as with all these things, demo before you buy.. there's lots of things to consider with hd tv's.. the number of hdmi inputs... if its fully hd (can take a 1080p signal and display it) my set wont display 1080p but then there's an argument that you wouldnt notice the difference between 1080i or 720p or 1080p on a 32" set.. if you are looking at a 40" plus set i would defintelty be considering 1080p as a requirement..
Happy shopping with whatever you decide on
Cheers,
Mick
Kit: Sony KDL-40W4000 LCD TV (ISF CALIBRATED), 250GB PS3 Slim, Sky HD, Denon AVR-1910 Receiver, MA225HD Centre, 225HD Fronts, 90HD surrounds, MA RSW12 sub, Harmony 1100 remote, Sony NWX1060 Walkman, Phillips 17PF4310 17' WS LCD TV
