| Re: Philips 20" crt, no remote, how to tune?
The model no will be needed but I can tell you you will require a remote to enter the Installation menu...I doubt a one-for-all type will do as it won't have the installation buttons on it which have icons which look like a "Diamond" and "half-Diamond" on them...these two buttons are pressed together and that brings up the installation menu and allows you to search for and store the channels.
This system of tuning was used on most of the Philips models of that vintage so even if you know of a friend neighbour or relative who has a Philips TV you could ask to try their remote...other than that just Google the TV model no such as "Philips 25PT5324 Remote Control" (obviously replace that model no with yours) and that should find some web suppliers of replacement remotes.
JayCee Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
